NX-8v2 "Control Phone Trouble"
Old 09-21-17, 11:23 AM
R
Hello everyone!
I tried to install a new (so I think it looks new - with resistors and clips of wire still connected to the zones and other contacts) board to replace an existing board that has started to over heat. When I connect the new board up it gives "Control Phone Trouble" error that I could not clear. I know the phone line is good because the old board works with no problems at all.
Is that a new board "thing", and I am not installing it correctly?
Thanks,
RK
Old 09-21-17, 04:11 PM
Received 77 Votes on 73 Posts
That sounds like it may have been previously used. A new NX board has nothing attached to it with the resistors taped to the battery wires.
I am assuming that you went into programming and set all of the configuration settings to match the board you were swapping out?
That trouble indicates that the panel is not detecting telco line voltage on the T & R terminals.
Old 09-22-17, 03:12 PM
R
It was probably used, yes. When I attached this other board on, and wired up everything, it immediately went into "Control Phone Trouble" and I could not silence it... I will try again when I have the chance...
