Connecting PIR sensor lowers auxout voltage
Old 10-06-17, 08:41 PM
O
When i connect my PIR sensor power to the auxout/com on my alarm board, the aux/com goes from 12v down to 3v.
I tried using a different wire as well as a new different sensor, but i'm still running into the same problem.
I'm stumped on what else to try, so any ideas would be great.
Thank you
I took a photo of the wiring diagram if that helps
Old 10-06-17, 09:51 PM
Received 913 Votes on 853 Posts
Welcome to the forums.
The Aux out 1 and Aux Out 2 are only used for switchable devices like a horn or siren. You need to connect to terminals 7 and 8 for AUX power. Those output terminals are listed for 1A maximum current draw. One PIR should not present a problem.
Name:  alarm diagram.jpg
Old 10-07-17, 10:57 AM
O
Yep that worked. Thank you for your great reply. I appreciate it.
