Safewatch 2000 master code reset Problem
Old 10-12-17, 05:36 PM
So I have read the threads on this and have the VISTA 20se installation instructions and think I am following the correct process to set the master code without the original code when it was ADT, but I have run into a snag. When I power up and get into programming mode by pushing *&#, I try to read the installer code by #20 and get EE. ??
I do have a broken wireless door switch which is giving me 09 CHECK alarm if I just let it power up on its own. Am I correcect to assume that alert is due to that? Could that be the reason I can't get the installer code to display for me. Also,I don't have the alphanumeric key pad, just the one with numbers.
Old 10-12-17, 07:12 PM
Received 322 Upvotes on 297 Posts
EE means that the original installer used the download software to disable local programming access. All you can realistically do is start over with a new motherboard.
Old 10-12-17, 07:28 PM
Well I guess I am glad I didn't go to much further guessing what to do. Thanks for letting me know.
I have seen you help many others with these systems.
So maybe I will look for a new vista 20 mother board or would suggest going with an upgrade? Something that I could expand some day to internet smart phone alarm alerts and control?
Could I use all my home wired switches, motions and wireless switches?
Old 10-13-17, 02:15 AM
A swap to Vista 20p would allow you to use all of your existing devices. You might need to replace one of the keypads if you don't have a 2-line alpha model. You would, of course be starting from scratch, in terms of programming and configuration.
