Programming Honeywell CE3 encryptor
Old 11-04-17, 11:29 PM
i have a new honeywell code encryptor Ce3.
I don;t understand how to programming it according the manual
I read to create an user code , but how ???? should go to the programming mode of my
vista 20P panel or is the CE3 plug and play?
Who can help.
Thanks
Old 11-05-17, 09:03 AM
Received 913 Votes on 853 Posts
I moved your thread to the alarms forum.
Is this for you unit.... CE3 Code Encryptor Installation Manual.pdf
Old 11-05-17, 11:57 AM
Received 77 Votes on 73 Posts
The code is a valid arm/disarm code programmed into the base alarm panel. So you create a user code for the Vista 20p and then program it into the CE3 receiver module.
Old 11-08-17, 04:36 AM
Thanks a lot a will take a note of it
Old 11-09-17, 02:24 PM
Thanks it work but at but have address it to 17.
With out this i would not.
Old 11-09-17, 02:57 PM
Yes, the system treats it as a keypad; so it had to be set to an unused, but activated, keypad address slot.
