GE Concord 4 BUS FAILURE UNIT 0
Old 11-08-17, 11:06 AM
G
I have what I suspect is a simple issue. I powered down my panel, including the battery backup, and replaced a defective keypad. Upon powering up, I now have a BUS FAILURE UNIT 0 error. I'm assuming this is because there's a different panel now. Everything works, I just want to clear this error. Yes, I have the installer code, so I suspect this should be easy.
Old 11-08-17, 04:45 PM
Received 77 Votes on 73 Posts
You delete the removed device in the accessories module menu (page 73 in the installer manual: http://static.interlogix.com/library...ion-manual.pdf)
Old 11-08-17, 04:52 PM
G
Yep, I did some searching and figured it out. Thanks for the reply.
