Upgrade 20p PROM from 5.2 to 9.12?
Old 11-14-17, 10:22 AM
My Vista 20p has been running 5.2 PROM since day 1 I just bought some used equip and it has a 9.12 PROM in it. Can I simply power down and replace the 5.2 with 9.12 PROM? Or ?
thanks for the help!
Old 11-14-17, 07:41 PM
Since your configuration is stored in the PROM, there really is no advantage to just swapping the chip; since you would still have to reprogram all of your zones and settings.
Old 11-23-17, 09:51 PM
Post Honeywell Vista 20P -- upgrading ROM question
My 20p has been running 5.2 PROM since day 1 I just bought some used equip and it has a 9.12 PROM in it. Can I simply power down and replace the 5.2 with 9.12 PROM? Or ?
Old 11-24-17, 12:45 AM
You already asked this question and received a reply. https://www.doityourself.com/forum/e...-2-9-12-a.html
So, unless you desire to re-program the entire system the answer is NO.
Why do you want to change the PROM? What do you expect to gain from the newer PROM?
Old 11-24-17, 10:04 AM
I'm seeing other into on the web saying (posted 9 months ago) ...
"As long as your chip is a version 2.# or later, your board is a version 2 and you can prom upgrade (thereby not losing any programming)."
https://disqus.com/home/discussion/a...0p_alarm_grid/
I'm considering using Total Connect which requires 9.12 and since I already have the 9.12 PROM I figured why not put it in, just in case.
Old 11-24-17, 10:15 AM
