NX6 Control Panel Showing Spanish Language
Old 12-10-17, 05:34 PM
H
One of the two control panels (NX6) is showing on the display in Spanish. I reset the power, unplug the power as well as unplug the battery. It started after I reset the system after a fire alarm was triggered. I think I did the wrong sequence on this panel when trying to reset it. How do I get this one control panel back to English.
Old 12-10-17, 05:40 PM
Received 1,189 Votes on 1,100 Posts
Welcome to the forums.
It's more than likely a setting in the keypad programming itself.
Can you post the model number of the keypad ?
Old 12-18-17, 06:32 PM
H
Where would I find the model number. Itís not obvious. I could send a picture.
Old 12-18-17, 06:40 PM
Posting a picture here would help...... How-to-insert-pictures
Old 12-19-17, 03:27 AM
Received 103 Votes on 95 Posts
Most likely it's a NX-148e. The language is toggled by pressing *49 (you may be prompted for the master code).
http://www.americansafeinc.com/PDF%2...n%20manual.pdf
