Tuxedo Touch WiFi attempts to login to my router
Old 04-19-18, 08:57 PM
R
After changing the default admin password on my netgear r8000 router I see illegal login attempts in the router logs from the IP address assigned to the Tuxedo Touch. Funny thing is the r8000 is in access point mode and isnít the router on my network. I use ClearOS as my router.
I donít use up upnp/miniupnp for port forwarding so I think the tux is attempting to setup port forwarding. Iíve never seen such an aggressive device.
Old 04-20-18, 02:49 AM
Received 45 Votes on 44 Posts
The Tuxedo Touch has a number of functions that require port forwarding, if implemented. Without digging in the manual, that port seeking can be turned off, but I think that is is active, by default.
Old 05-28-18, 09:49 AM
R
Log snipit:
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:45:33
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:45:23
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:45:13
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:45:03
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:44:53
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:44:43
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:44:33
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:44:23
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:44:13
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:44:03
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:43:53
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:43:43
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:43:33
[Admin login failure] from source 192.168.6.200, Monday, May 28,2018 11:43:2
Old 05-28-18, 01:22 PM
Starting on page 13 of the manual, you can turn off this feature:
https://library.ademconet.com/MWT/fs...etup-Guide.PDF
Old 06-05-18, 10:37 PM
R
So your suggesting removing the device from the network?
Old 06-06-18, 02:37 AM
If you are not using any of the features that require that kind of network access, then you can turn off the network feature, should you choose.
Old 09-15-18, 08:09 PM
R
I use the weather forecast.
Old 03-31-19, 09:20 PM
R
Anyone have any ideas stopping this?
