DSC 1555 - Replaced backup battery and OPEN and Trouble won't go off
So, I replaced the backup battery because I kept getting calls from the security company saying it was low and needed to be changed.
After changing it, the Trouble light has been on and also it says OPEN on the screen as if a door was open but they are all closed.
After using the *2 to see the trouble code I get a 1 and then after hitting 1 again I get a 5.
Any ideas on what is wrong?
On a guess, while removing the old and installing the new battery; you may have dislodged or broken a wire going to a keypad or system module:
http://cms.dsc.com/download2.php?t=1&id=13789
Take a close look at the wires going to the keypad connections; sometimes the break can be subtle.
So the zone that is always staying open is a motion sensor. It doesn't even turn red as I walk by anymore.
In the box, zone 6 (which is the motion) has a red wire that is not attached to anything.
Is that the issue?
Is that the issue?
