V20p 2 new problems, and I thought I was doing so well!
Old 05-31-18, 11:54 PM
I have 2 brand new problems. First I was trying to install a key fob in expert mode,zone 53, number 3, and when It showed the 2nd descriptor, it should have led to the 'Serial Number' entry, but 'Partition 1' displayed. I pressed star to get out. Repeating, same result. Needless to say it didn't install. The second problem happened next: When I was restoring AC , after the Standby message, the 6160rf said CHECK 100 RF RECEIVER. That message and the Disarm Bypass, Ready to arm, alternate on the display. I powered down and noticed the keypad negative power wire was slightly loose. I secured it and powered up. Same display.. That's where I'm at. Thanks for any suggestions...
Old 06-01-18, 03:05 AM
Pg 42 of the Programming Guide, various trouble displays .. CHECK 1xx it's the display. My mssg says check 100. Maybe zone 100? I'll do a system check and see if all my wreless sensors report.
Old 06-01-18, 03:44 AM
I think my 'check 100 RF' problem is gone..
After doing a Test all wireless sensors reported and after quitting I went to programming (20) to view zone 100 and without recognizing there are only 56 zones... I put in 100 and settled for 00. And got out... Now the problem is gone! I will do more reading and highlighting the User's Guide (ie page 43) and Programming Guide.
Old 06-01-18, 09:46 PM
Key fob works!
I got it working. I had one zone type wrong. I had Trouble when it should have been Arm Away. Then it "authorized". No problems.
I disabled zone 08 which was having to be bypassed. Disabled but not Deleted.
