DSC LCD600 compatible with PC3000RK
Old 06-02-18, 03:35 PM
Hi,
I have a alarm system DSC PC3000 with a initial keypad LCD600. I would like to add another keypad and I find a keypad PC3000RK. Is it compatible? Is it necessary to reprogram the second keypad? And how to proceed to do that? Thank you
Old 06-03-18, 12:04 AM
The PK3000RK is actually the base keypad designed for the system. The LCD600 was a more advanced keypad that worked on several system models, that was often sold as an upgrade.
Bear in mind, that this is all 15-20 year old, discontinued hardware, at best.
Old 06-04-18, 05:23 AM
I know that this hardware is discontinued but I found a keypad PK3000RK and I would like to know if I can connect in parallel (together) this new keypad at the LCD600. If yes, for the PK3000RK, I must reprogramming or if it is like the LCD600; the programming continues with the other keypad.
Thank you
Old 06-04-18, 04:27 PM
The PC3000RK is the factory default keypad for the system; it will work just fine along with the upgrade keypad.
