Vista 10SE and 5834-4 Remote
Old 06-22-18, 05:12 PM
D
I am trying to program the 5834-4 Keyfob(I purchased two) with my Vista 10SE System. I have the Keypad 6128RF and a 6160. I was told that I can program the Remotes Locally to the 6128RF so that it doesn't take a Zone in the panel, is this true and what is the procedure? I would like to save my last 8 available wireless Zones I have left. If I can't program them locally to the controller can I only use 3 of the 4 buttons on the remote(not use panic)?
What Security mode would I use on the keyfob(low or high security)?
Old 06-23-18, 09:20 PM
It's a fair number of steps. Do you have the installer manual for the 6128RF?
https://library.ademconet.com/MWT/fs...ions-(New).PDF
As far as the security mode, stay with the low security mode. For what you are trying to do, there is no significant benefit to use Hi mode.
Old 06-24-18, 08:34 PM
D
I followed the steps, but when I get to pressing 8 on the controller nothing happens.
Old 06-25-18, 05:07 PM
Are you removing power from the keypad, and restoring it before pressing 1 + 3 to enter program mode?
Old 07-02-18, 09:59 AM
D
Yes, I unplugged the connector from the keypad temporarily, and reconnected it, I hit the 1 + 3 and I am in programming mode with --oo flashing.
Old 07-02-18, 04:59 PM
Missed a line on the chart in the manual. Vista 10se does not allow the local wireless key option with this keypad. You _have_ to enroll them as zones.
Old 07-09-18, 10:44 AM
D
No problem, I just programmed them as zones (I didn't use the panics) so it only used 6 zones for two. It was weird that I didn't have to program the user code for each remote.
Old 07-09-18, 05:12 PM
The older SE model panels didn't require linking the remotes to a user code.
