Honeywell keypads that has the 4 beeps for carbon monoxide
Old 09-06-18, 04:23 AM
Andoy33's Avatar
Received 5 Votes on 5 Posts
hello I recently installed a Honeywell vista 20p from a 10se and reused all the keypads and equipment. I added 2 carbon monoxide sensors and programmed them as carbon monoxide zone types. One day there was a ventilation problem with the water heater and the carbon monoxide sensor went off as it should. We had the water heater repaired by a professional and everything is well again but I noticed my 6148 keypad and 6160 keypad both with date code Honeywell 2010 on the motherboard of the keypad didnít give off a 4 beep for carbon monoxide alarms but only a fire alarm beeps. Which Honeywell keypad will give off the 4 beep for carbon monoxide alarms ? Iíve seen YouTube videos of 6160 keypads doing the 4 beep for carbon monoxide but Iím not sure which date code would include them thanks.
Old 09-06-18, 03:57 PM
Received 92 Votes on 85 Posts
That tone would be generated by the system programming. It's not inherent to the keypad. Usually it would come from the siren, and not from the keypad, in any case.
