Program Z 1100 zone for keyswitch
I would like to program one of the zones on my Z 1100 panel door with the key switch I would like to set it up to arm it self every night at a certain time I’ve looked at the manual that I have and I’m not sure how to program the zone to be a key switch zone. Anyone here able to help me? Thanks so much
Programming a Keyswitch Zone
- If you want the zone to be a keyswitch zone, write down 5 for that zone.
- If you want the zone to be SHUNTABLE, write down 8 for that zone.
- If you want the zone to be supervisory, write down 128 for that zone.
A word to the wise: Make sure you have battery backup on the timer you connect to the keyswitch zone. And don't forget about Daylight Savings Time.
Z1100
It’s a Z1100. I have a couple manuals but I’m not sure there is a exact ones for this panel everything is working great but I just wanted to make a zone that I could have it arm itself every night I really appreciate your help
It should be this manual: https://www.manualslib.com/manual/11...ose-Z1100.html
Bear in mind, this hardware is over 20 years old...
