NX-8V2, NX-1192E Keypad Fire Light Stays On
Old 11-24-18, 01:47 PM
W
NX-8V2 system with NX-595E card and NX-1192 LCD Keyboard. The RED fire light on the keypad stays ON without beeping. How to reset the RED fire light off?
Incident: We disconnect the 2 wires to fire alarm (Bosch D263) accidently. After reconnecting, the red light flashing and beeping. Reset with *7 and the disarm code several times, the system stops beeping, but the keypad Red light stays ON.
Perform a system reboot, i.e. disconnect battery and power to the system, then reconnect the Red light is still ON.
Cannot find procedure to reset fire alarm using DLX900.
How to turn off Red fire alarm light on keypad? Appreciate any help.
Old 11-24-18, 02:20 PM
W
Found one wire at the detector was loose. Reconnect and the issue was solved. Red fire alarm light means "faulty" fire detector system. It must the connections and/or the detector itself.
