What Kind of ADT System is this ?
So i was helping my step dad clean up his new house he bought and while i was away getting wood flooring adt stopped by and installed adt pulse cameras and a adt system that i've never seen before. the keypad is on the coffee table and theres a base station with buttons but with no display just leds displaying its status. Is this a new system adt offers now ? i usually only recall them installing either the lynx plus , safewatch 3000 or dsc system. here are photos i attached on the bottom of it.
After much research and playing with the system it turned out to be a adt Tssc system. The base station is a Honeywell lyric that was heavily modified and made to only communicate with adt only. The back has a Ethernet jack and a built in z wave commutator , WiFi and at&t 4g Lte. The keypad is wireless and doesn’t talk nor does the base station. The wireless sensors are the lyric sensors except for the smoke detector which is a 2gig strangely.
Received 0 Votes
Help
I had this system installed yesterday. ADT wanted $80 for a window sensor and I needed 7. I found the same exact sensor on Amazon and ordered them for $15 each. ADT will not come back to install them.
I need to know how to put the system into program mode, so I can add the sensors to my system.
Any help would greatly be appreciated.
Bill
Bill
Not knowing just how heavily ADT had the base system modified, here's the manual for the Lyric system:
https://advancedsecurityllc.com/wp-c...n%20Manual.pdf
The typical installer code that ADT uses can be readily found by web search using the phrase "ADT installer code" (they complain if it's posted on this forum).
Let us know if there are concepts and/or steps in the process that you need translation of.
After playing around with the system. The system sadly can’t enter programming mode after trying all the typical adt installer codes. They have locked the system entirely and the backdoor method doesn’t work as well. I’m not sure how they programmed this system as I wasn’t here when they programmed it. It seems like adt is following brinks foot steps and using proprietary equipment like the BHS series systems.
