DSC 1555 - smoke detector replacement
Old 01-10-19, 08:01 AM
T
I am trying to replace the ceiling mounted smoke detector on my PC 1555 panel. I have attached three pictures of the existing wiring. Any suggestions.
Old 01-10-19, 04:02 PM
Received 312 Upvotes on 287 Posts
To a certain extent, you actually zoomed in a little too much. Based on what's visible, it looks like someone installed a 4 wire smoke, and used the junction box for a 120v hardwired smoke as the mounting location (technically a little sketchy, code wise).
In any case, you can replace it with any standard 4 wire smoke. I recommend the System Sensor 4-WB.
https://www.systemsensor.com/en-us/Pages/4W-B.aspx
Old 01-14-19, 05:04 AM
T
Thanks...I ended up replacing it with a DSC. All working. Thanks for your assistance.
