Need Help with DSC Alarm System aka SCW9047
Old 04-06-19, 12:22 PM
C
Exclamation Need Help with DSC Alarm System aka SCW9047
Need some help with an older DSC Alarm System. I have a SCW9047-433.
1. Trying to add some additional sensors. Trying to add a keyfob WT4989 and a Siren WT4901 They would not install on the quick install, so I accessed by entering 804 to add manually. My keypad only allows a 6 digit serial numbers and these have 8. What do I do? Also how do I ensure it's labeling the zone type correctly?
2. I also manually added another smoke detector and carbon monoxide detector, how do I test them and check the zone definitions?I have a SCW9047-433 or also known as DSC system. My keypad only allows a 6 digit serial number and these have 8.
Old 04-07-19, 08:24 AM
O
Wireless model numbers for the SCW9047 must begin with "WS", not "WT". If you want to use "WT" devices your panel must be an Alexor/Impassa or you must have the TR5164-433.
Old 04-24-19, 04:45 PM
C
OngoGablogian, would you recommend upgrading to a DSC Impassa 9057 so I can use my existing sensors as well as the WT ones? Or is there a better route?
