Napco Magnum Alert 1008LKDL programming parameter
Old 04-19-19, 08:04 AM
Hello All
I have a 1008LKDL panel that I am currently reprogramming however cant find the parameter for the keypad sounder keystrokes for when i press a key. This function is available on the panel as it was being used before or maybe it was some magic done by the original installer company (no longer active) does anybody know the programming block for the keystroke sounder function and while im at it also the zone display function?
Thank you all God bless!
Old 04-20-19, 03:39 PM
Go to location 181 and add a 4 to what ever is there now.
Also I don't know what you mean by "the zone display function"
Old 04-20-19, 03:48 PM
also I don't know what you mean by "The zone display function."
Old 04-25-19, 10:35 AM
Thank you very much Jimmie! I tried Location 181 but just cant get the keystroke sounder to activate everything else works fine. Also what I meant by the "zone display function" is actually displaying the zone number when a zone is tripped ive seen that feature on these panels before but cant remember the location and value for this feature
Thanks for responding
God bless!
Old 04-25-19, 02:57 PM
It's possible that the piezo in the keypad has simply failed. Does the keypad chime if the zone chime feature is turned on?
Old 05-15-19, 07:13 PM
The Sounder works fine as when i do a hold function it beeps as well as the chime setting sorry for the late response
Old 05-16-19, 03:02 PM
What is the setting currently programmed in location 181?
