Honeywell Lynx Plus (ADT) Repair
Old 04-21-19, 08:24 PM
demetrax1's Avatar
Hey all,
I have a Honeywell Lynx Plus here that I'm trying to revive. I tried applying AC power, but nothing. I flipped the board over and found a component behind the AC terminals that was black/burned. There was obviously a power surge or some other electrical malfunction. Does anybody know what this component is so I can replace it? It should be as easy as finding the right part and soldering on a new one. Please see the attached pictures. Any help would be appreciated!
Thanks,
Demetri
https://1drv.ms/f/s!AjlfjNZxVgE9hAgHj-LZXP67rryn
Old 04-22-19, 07:43 PM
Received 1,399 Votes on 1,296 Posts
Your picture looks like it's on one drive. Typically those are private pictures. I don't know if they can be made public. You could post it directly to the board...... How-to-insert-pictures.
Old 04-23-19, 03:59 AM
Received 120 Votes on 111 Posts
In general, most of those components on these all in one boxes, are surface mounted devices that require some specialty techniques to put them on the PC board. That, and something that could hit one of these hard enough to burn a component, probably did more damage than just the obvious.
ThisOldMan voted this post useful.
Old 04-23-19, 07:46 PM
demetrax1's Avatar
Hey all, the OneDrive link should work as it is a shared link. I attached the image to this post just in case. Thanks PJmax!
You can see the burn marks on the board directly behind the AC terminals. None of the other components on the board seem to be damaged (i.e. no discoloration, leaking capacitors or other obvious damage.) If all it takes is one measly component to bring this back to life, I'd like to think it's worth it. Any thoughts?
Old 04-23-19, 09:20 PM
It's more than just one part. It looks like several are heat damaged.
Old 04-23-19, 10:39 PM
P
Received 3 Votes on 2 Posts
You can buy a used Lynx Plus on EBay for $20.
Old 04-29-19, 06:44 PM
demetrax1's Avatar
Oof, that's what I feared. Must've been a power surge. Oh well. I'd prefer to find an ADEMCO-branded panel over a proprietary ADT one any day.
Old 05-03-19, 08:05 AM
Andoy33's Avatar
Received 5 Votes on 5 Posts
I recommend the lynx touch panels if your looking for a replacement. They are much easier to program and you get a touch screen
