Need address / baudrate from camera
Old 05-07-19, 01:36 PM
Unhappy Need address / baudrate from camera
I am new to POE Ip cameras I have PTZ dome camera hooked up through video balun when i plug camera in it will pan and tilt but does not show the important info i need to setup camera and dvr to comunicate properly.
aynone know how i can get camera to display this address / baudrate protocol info on intial start up of the camera
Old 05-07-19, 02:09 PM
Brand and model needed. These things all vary wildly from brand and model.
There's not really a standard.
Old 05-07-19, 03:20 PM
Secuplug
Model Number SP-PHD54FDM55OAP
Old 05-07-19, 03:39 PM
Secuplug appears to be a Chinese company with no website or any technical information supplied. I can't find any mention of the camera model you posted. The only thing I did find was Ispyconnect offers free video software that may be beneficial.
Ispyconnect
Old 05-07-19, 03:45 PM
yeah i saw that but would still have to be connected to the intert for it to get the info from camera i need
Thank you for your help
Old 05-07-19, 03:49 PM
An agent would be a program on your computer. Your computer and that camera would need to be plugged into the same router. When you open the agent and scan for cameras..... yours should appear. The IP will be listed. Usually you can enter that IP directly and the camera will open to a page that would say admin and ask for a password. It would be a default password that you then must change to your own. Unfortunately with that camera..... the user cannot be changed from admin.
Actually if you have access to your routers information..... you can see the camera there too. No agent needed to access it.
Old 05-07-19, 04:43 PM
Thank you for your help, I have been reading that dome can be taken apart and DIP switches for setting of camera can be found for baudrate and Address to communicate with DVR propely not sure if i am going to take it apart
Old 05-07-19, 05:32 PM
The only info I had come across with those domes in general is that the covers were hard to get off. Typically there are three screws holding it on. I haven't found that camera so I haven't seen a picture of it. You really need the default info from the manufacturer as it will contain the default password. Without that you can't do any reprogramming.
Old 05-07-19, 06:43 PM
I will keep searching and reading and try to figure it out in the instructions that come with camera user name is admin ( No password )
