security system vs phone help
Old 05-23-19, 04:53 PM
We cancelled our alarm monitoring 13 years ago. Yesterday it came back to life and the siren went off and the only way to shut if off was to cut the power. After disconnecting the siren we noticed the phones had no dial tone. Is this a DIY fix or should I call a pro?
Old 05-23-19, 05:02 PM
It can be a DIY repair. We need to know what you have there.
A picture of the alarm board would be helpful..... How-to-insert-pictures.
Old 05-23-19, 05:40 PM
pics of the wiring and wiring diagram below (voxcom)
Old 05-23-19, 06:19 PM
I added the last picture. That plug I circled is the alarm phone line and is not connected.
Old 05-23-19, 06:56 PM
Pretty sure that has been like that for years. At least since they installed the home hub system (Bell Fibe). If that is the problem, where do I connect it. The box it goes to (above right) is not connected to anything?
Old 05-23-19, 06:59 PM
With that plug not connected...... the alarm system is not the cause of the loss of phones.
Old 05-24-19, 03:02 PM
It's a dsc PC5010 (AKA "Power 832")
Installer manual: https://cms.dsc.com/download2.php?t=1&id=13802
Programming sheets: https://cms.dsc.com/download2.php?t=1&id=13805
For the phone problem, I would check to see if the fiber adapter has power, or just needs to be power cycled. You may have had enough of a power hiccup to glitch both that, and set the alarm into activation.
But as pointed out, with the alarm phone cord unplugged from it's jack, the alarm system has zero connection to your phone system. If you killed the alarm by throwing the breaker, your phone adaptor may be on the same circuit...
The alarm is a good, basic system, and could be made functional, should you choose.
Old 05-24-19, 08:39 PM
You guys nailed it. Turns out is was a neighbour who was trimming his grass and sliced through both the old and new phone cables outside our property. The box was installed improperly leaving exposed cables underneath. The old one tripped the alarm via a tamper?? And the new one was also destroyed. Me cutting the siren was not the cause. We had all the cables replaced today free of charge. Thanks for the expertise.
Old 05-24-19, 10:06 PM
Thanks for letting us know how you made out.
