compatible motion
Old 06-02-19, 05:19 PM
compatible motion
Would anyone please be able to advise Honeywell part numbers for USA Commercial UL-Listed Dual-Tec motion detectors that are compatible with the Vista-128 control panels? ADI-Global states that the IS2500SN and DT2500SN have been discontinued.
PS needs to be hard wired!
Thank you.
Old 06-02-19, 10:13 PM
Received 14 Votes on 14 Posts
The first online store I checked seems to have IS2500SN PIRs available.
https://alarmsuperstore.com/store/in...x&cPath=1_6_45
If they've been discontinued, and you feel the need to have the latest replacement model, and/or you only buy at ADI, you can ask at your nearest ADI outlet for its replacement.
Other than that, there are options for fitting any hardwire motion sensor on a V-Plex loop, by incorporating a 4190SN module on the V-Plex polling loop.
Old 06-02-19, 11:12 PM
Must we use a 4190SN module?
Thank you
Old 06-03-19, 12:43 AM
No, you don't "must" use a 4190SN module. That's just an option if you need to put a non-polling loop motion sensor on a V-Plex polling loop. It can adapt any non-polling motion to the polling loop, for zone expansion.
I probably should have asked about your situation before I answered. The IS2500SN PIR that you referenced is designed to be used on a V-Plex polling loop, so I assumed that you were looking for a replacement motion sensor to replace an existing sensor that is already installed on the V-Plex polling loop of a Vista-128 that's already in use.
Are you replacing an existing IS2500SN? If so, why?
Or are you adding to an existing system, or installing a new system? Or what?
Old 06-03-19, 02:24 PM
Thank you...No. We are replacing a wireless 5898 Dual Tec with a Hard wired motion sensor. We were told to go with the Honeywell hard wired commercial CK-DT8050A Dual Tec Motion and use a zone expander. We were planning on using a Honeywell 4208U 8-Zone universal zone expander. Would you know if there is a limit for the number of zone expanders that can be used on the VISTA-128BPT SIA Control? Because we have one 4208U already and all connections are used.
Thank you.
Best regards,
PCSEC
Old 06-03-19, 07:30 PM
Received 35 Votes on 34 Posts
A Vista 128 can handle 31 addressable devices (keypads, RF recievers, relay modules, expansion cards, etc).
If you are using a standard zone, and not the addressable V-Plex, then you can use any industry standard 12volt powered motion detector. Brand doesn't matter, as long as it has a zone connection and power.
