Need Help With A Destiny 6100 Alarm - No Delay On Door Fix
Old 08-17-19, 10:20 AM
Smile Need Help With A Destiny 6100 Alarm - No Delay On Door Fix
Howdy,
Recently bought a home with the Destiny 6100. Our side door is the one we use all the time. If I enable the alarm, once I re-enter, the alarm is immediately trigged. We need a delay so that the police are not dispatched from central station.
I know very little about this system, so a step by step to solve this woudl be greatly appreciated.
Thank you in advance.
Old 08-17-19, 11:47 AM
Received 30 Votes on 29 Posts
The simple, no programming, solution is to identify the pair of wires for that door and connect them to the same input zone as the door(s) that are already on delay configuration.
As you can see from the manual, these are an older design, and are not super DIY friendly for programming. It's also old enough, the you might seriously want to budget in a more modern replacement.
http://www.safe-tech.net/HONNEWELL/I...INY6100_EI.pdf
Old 08-17-19, 12:57 PM
Understood. A programming solution is preferred if someone has the guidance.
Old 08-17-19, 01:29 PM
Look on page 23 of the installer manual. Read through that, and let us know what parts you need clarification on.
There's no "cookie cutter" formula for this; alarm installations are essentially custom installations.
