Delay Time
Old 09-12-19, 03:25 PM
Delay Time
New House- Concord 4 system - How do I check the delay time and change it if needed to give more time to exit and entry from garage?
Old 09-12-19, 03:46 PM
Received 25 Votes on 24 Posts
The easy way to _check_ the delay times, is to arm the system and time how long it takes for the arming countdown to stop. For the entry delay, if it's a monitored system; put your account on test, then open an entry/exit door and time how long it takes before the warning tone runs out, and the alarm sounds.
(if you have close neighbors, probably wouldn't hurt to warn them, ahead of time)
Changing the delay times requires having the installer code, because that has to be done in installer programming.
Do you have the installation code?
