Manual needed for Ademco/Honeywell m6983 security system
Have an older security system and cannot locate manual. Getting codes I need to lookup & would like to be able to change our current code access.
Welcome to the forums.
I believe you've posted a keypad model number. That won't help. You need to locate the main alarm box and get the model information from there. It may be printed right on the inside of the door.
Actually, that isn't a keypad model number either. I suspect it's from the raised lettering on the keypad plastic housing, which doesn't tell you the KP model number. But PJMax is right, even if it were a KP model number, we'd still need to know the model number of the Control Panel, the "brains" of the system located inside a steel cabinet, about the size of a bathroom medicine cabinet, usually in a closet, utility area, or basement.
