House to i get codes for Concord
Old 01-03-20, 04:31 PM
Buying a house with Concord 60-806, and seller does not know the master code. What can I do?
Old 01-04-20, 05:42 AM
Received 116 Votes on 107 Posts
That would be a Concord Express.
(Installer Manual: https://static.interlogix.com/librar...%20REV%20J.pdf) (User Manual: https://static.interlogix.com/librar...%20REV%20J.pdf)
There is no easy "back door" way to set a new master code on Concords.
The default code is 1234, but it's a fair bet that they changed it, then forgot the code; or never had the code and didn't use the system.
The default installer code is 4321, again, probably changed. You can try and see if either will let you into the user programming by pressing 9 + [code].
If the original installer (or another concord dealer) still exists, you might come out best to find out how much they would charge to connect to the system and set the master and installer codes to numbers of your choice.
