Replacing DSC Alexor alarm
I have dsc alexor alarm which is time to replace. I would love to continue utilizing all the sensors that are on 433 mhz. I know there is new 900 frequency which eventually i will buy sensors to change to that but to safe money for now i would love to if possible to keep using my sensors that i have until they die.
Can someone recommend what my options are?
The 433mHz is still one of the DSC product lines.
The 915mHz (PowerG) products are just a new product line; but you can still get a new Alexor, or even the regular Power Series systems that are compatible with your existing devices.
https://www.dsc.com/index.php?n=products
Interesting point you made and i am confused as I though that Alexor was discontinued and never replaced? Any particular Power G that you would recommend ?
Not PowerG (that's the 915 mHz wireless)..._Power Series_ (PC1616/1832/1864), or Impassa (SCW9057).
The Alexor is recently enough discontinued, that you probably could still find one with a little shopping effort.
It does look like that Johnson Controls/Tyco (which absorbed DSC) is phasing out the 433 mHz models. There is a _huge_ installed base; though, so they may be supporting them for a goodly length of time.
alexorowner
voted this post useful.
alexorowner
In that case do any of PowerG come with 3g or better yet 4g? Am I better at just looking to replace my system completely?
The new stuff is modular. You add the components to get the features you want, beyond the standard:
https://www.dsc.com/index.php?n=products&o=view&id=2669
https://www.dsc.com/index.php?n=products&o=view&id=2659
https://www.dsc.com/index.php?n=Prod...ain&filter=6,7
Thanks for reply and posting those links. I think i am going to try to stick with Power G that is compatible with 433mhz. However i am little confused if there is any that can support both 915mhz frequency and old 433 mhz? For example i am seeing this one https://www.alarmsystemstore.com/pro...6-alarm-system ,can this support both 433 and 915 or only one? Also what other models would i need to buy to be able to work with my current equipment. Basically i am trying to figure out what i can buy to keep my cost down and at the same time be able to upgrade as time goes by to 915 mhz sensors.
At this point in time, DSC does not make a solution to use 433 mHz and 915 mHz on the same alarm control.
alexorowner
Thanks for letting me know. In that case, what is the best wireless system i can get that supports 433mhz that can monitor it using lte and as backup over the internet? Being sensors work fine i guess i can just stay on 433mhz for a while. Thanks for all of your help Honestly a bit confused on dsc system support so if you could link it would be very appreciated.
