DSC PC1832 Fire Zone Programming
Old 06-28-20, 07:24 PM
B
I have a DSC PC1832 alarm panel with 3 System Sensor 2012JA 4-wire smoke detectors. I want each smoke on a different zone.
Here is how they are programmed:
Zone 7- 2nd floor smoke
Zone Definition: 08 24Hr fire
Red Wire - AUX+ on panel
Black Wire - PGM 1 on panel
Green Wire - COM on panel
White Wire - Zone 7 on panel
PGM 1 programmed as 03-Sensor Reset
Zone 9- main floor smoke
Black Wire - PGM 2 on panel
White Wire - Zone 9 on zone expander
PGM 2 programmed as 03-Sensor Reset
Zone 11- Basement smoke
Black Wire - PGM 3 on panel
White Wire - Zone 11 on panel
PGM 3 programmed as 03-Sensor Reset
5.6K resistor is between NO and COM on the smokes
Zone 7 smoke is fine, but zone 9 and 11 go into immediate alarm everytime. Why?
Old 06-29-20, 03:00 PM
Received 74 Votes on 70 Posts
A percentage of these power up with the relay toggled. If you enter silence and reset command, does everything settle at system normal?
Old 06-29-20, 04:05 PM
B
It does restore for 30 seconds or so, and then goes back into alarm.
Old 06-29-20, 05:02 PM
Basic test: Put the EOL just on the zone wires. Do you get an alarm? If so, then there is an issue with your field wiring, if not, then your detector relay may have an issue.
With power applied to the detector, but nothing connected to the relay terminals, are you getting a short/low ohms from common to NO?
Old 06-29-20, 08:05 PM
B
I took the zone wires right off the expander and put a resistor across zone 9 and common. No fire alarm but iy says the zone is open. This was previously a wireless motion zone, but I checked section 109 and only 1 is on. I checked 804 and the wireless esn is 000000. Is it because i have a smoke on pgm 1, 2, and 3? That should be fine as long as they are all programmed as sensor reset
Old 06-29-20, 08:12 PM
B
I took the zone wires right off the expander and put a resistor across zone 9 and common. No fire alarm but it says the zone is open. Even after a *72.
Old 06-30-20, 02:34 AM
The configuration of the PGMs has nothing to do with the zone configuration. If your zone is staying open with a resistor jumping it out, and no field wiring; then something is wrong with either the zone input itself, or the zone programming.
