NETWORX 148 (6SE) "EXPANDER WIRELESS JAM" report
Old 06-30-20, 01:44 AM
F
Hello,
Since a week ago I receice the following report "EXPANDER WIRELESS JAM(device 0))" on my ultrasync app. On my keypad *2 it's almost the same report.
After a some attempts to arm (4 to 6 times) the system accepts ARMING. Immediately I receive a report " WIRELESS JAM RESTORE device 0) followed instantly by again by "EXPANDER WIRELESS JAM(device 0))"
It's driving me nuts as you can understand
Where to look, how to resolve permanently, that's the question
Please help me fixing this, THXSSS
Old 07-01-20, 09:41 AM
Received 77 Votes on 73 Posts
It means that there is some RF interference present. Have you made any recent changes, like an upgrade to your WiFi router; new bi-directional wireless devices; or even something as odd as installing any large mirrors?
This is something that is nearly always environmental. Once in a blue moon, it's the receiver starting to fail, but that's pretty rare.
Old 07-03-20, 06:13 AM
F
Thxs RonFL
I am aware of those factors but they don' t play a roll. I've checked. The report remains: "EXPANDER RF JAMMING" ( device 0). Strange isn't?
Old 07-03-20, 05:47 PM
Short of bringing an RF analyzer to determine what is causing interference in the 319 mHz range; the most likely explanation is that the RF receiver is starting to fail. You _can_ turn off the jam detection feature, and if all the transmitters work correctly, then it's most likely an RF harmonic "ghost". I have yet to find a deliberate jamming attempt on a residential system.
Old 07-04-20, 10:19 AM
F
MrRonFL,
Wouldvit be an idea to do a hard reset ( power shutdown incl battery)?
Old 07-04-20, 02:19 PM
A power cycle never (well, rarely) hurts.
The RF jam detection can be turned off in the receiver options programming location (the specific is dependent on the specific receiver model). It's not part of the main system programming.
Generally a specific transmitter malfunction produces a zone specific trouble. There is a test function built in (again, varies a bit depending on receiver model).
Old 07-04-20, 11:47 PM
F
Thxs MrRonFL
I will first do the power cycle test. Thxs again. Keep you informed
Old 07-05-20, 10:36 PM
F
Do I need to use the master code or installer code to do the power cycle reset?
Old 07-06-20, 02:22 AM
You just disconnect it from ac power and the backup battery.
You reset the clock with the master code.
Old 07-06-20, 09:45 AM
F
MrRonFL,
"Just disconnect" resulted in a avalanche of Sirensound😒. Logical ofcourse but jeez what a noise. After a mastercode reset I did the "job" but IMit didn't work! Wireless jam report was in 30 sec back in its logbook position😗😗. Is it time fior an expert?
Old 07-06-20, 02:45 PM
Some configurations can sound the siren on power up.
Yes, at this point you need to determine if your problem is environmental, or if your receiver is failing.
Old 07-07-20, 09:49 PM
F
Thumbs up
Mr
RonFL
Thxs again for your help, I really apprecate this.
I will go the specialist. My tries aren't working for me.
