Motion detector flashing randomly
Old 06-30-20, 10:11 AM
R
I have a Honeywell IS2535 wired motion detector which has started to randomly flash its red led. I have verified that there is no motion in the area, and I opened the detector to make sure that there were no insects inside causing problems.
My home alarm system (Vista 20P) is unarmed while I am observing the sensor flashing. I disconnected the power to the sensor and let it sit unpowered for a half hour or so, but the flashing resumes when it is powered again.
I haven't had problems like this with sensors before and wanted to know if it is likely to be a sensor failure or if there is some other problem in my system that I should investigate.
Thanks.
Old 06-30-20, 10:14 AM
Received 847 Votes on 794 Posts
Double check for 12vdc.
If that is ok..... the sensor looks to be going bad.
Old 06-30-20, 10:31 AM
R
I should have mentioned that I did check the supply voltage at the sensor. The voltage was about 13.4V, but I assumed that was okay.
Old 06-30-20, 10:47 AM
At least 12v..... so 13.4 is also ok.
13.4v is a strange voltage to have.
Usually the sensors are connected to the panels AUX power which is regulated 12v.
