DSC PC5010 panel no sounds
Old 08-12-20, 08:58 AM
L
I have a DSC pc5010 panel and all of the sounds have stopped today even the chimes
The chimes setting is set to ON and the volume is set to 10 but still no sounds
Any ideas
Old 08-12-20, 03:51 PM
Received 103 Votes on 95 Posts
If you have checked the volume, and you are sure it's up, then the only thing remaining is the piezo sounder on the keypad has failed. All you can do for that is to get a new keypad. The one you have is likely a discontinued model, but the newer PK55xx keypads are backward compatible with the older alarm controls.
You would need the installer code to set up and enroll the replacement..
