Locating security wiring
Old 08-14-20, 01:40 PM
A
our 2004 house has wires to the windows and doors.
where are the other ends?
attic? crawlspace? garage?
is there usually a box?
thanks
Old 08-14-20, 01:52 PM
Received 1,021 Votes on 947 Posts
If you are finding alarm wires at doors and windows.... then yes.... there would have to be a control panel location. If no box.... at least wires. Typical locations are basement and closets anywhere in the house. Attic is typically too hot.
Old 08-14-20, 03:08 PM
A
thanks for your help
The message you have entered is too short. Please lengthen your message to at least 25 characters.
Old 08-14-20, 03:19 PM
Received 88 Votes on 83 Posts
Most common location is the master bedroom closet.
Old 08-14-20, 03:30 PM
Mr Ron.... in NJ it's shoehorned in the front coat closet.
Old 08-14-20, 03:32 PM
Here, in FL, that's usually the second choice, generally for post construction installs...
Old 08-14-20, 06:15 PM
A
Reminds me of the song " i been everywhere man...."!
PS in the hall closet is what looks like a transformer, i assume that is for the doorbell.
Old 08-14-20, 07:58 PM
If there has never been a system installed, if the prewire was done correctly, there will be a blank cover plate over where the wires should converge.
RockyTSquirrel voted this post useful.
Old 08-14-20, 08:48 PM
C
Received 34 Votes on 33 Posts
In the Wash. DC area, the preferred place is somewhere in the basement. I'm guessing there aren't many (any?) basements in FL, which would explain why Ron doesn't see many panels installed there. I grew up in basement-rare country much like FL, eastern NC, where the water table was too near the surface to make basements feasible.
Anon125, it might help if you mention what part of the country you're in. Might make a difference.
There's a surprising list of factors that make a difference about how a prewire _might_ be done. I once worked for one local company whose owner liked to _hide_ the control panel, and didn't keep records of where they were---sometimes I'd have to spend the first hour or more of a service call just finding the CP, for what could have been a 5-minute job.
Thankfully, that kind of thinking wasn't that common and you probably won't have that much trouble.
Old 08-14-20, 08:57 PM
If it plugs into a receptacle...... that could be for an alarm. See what it says on it.
Doorbell transformers are usually mounted at the electric panel.
Old 08-15-20, 09:58 AM
A
We are British Columbia Canada (north of Seattle)
Old 08-15-20, 10:12 AM
That is a setup for a door bell. One wire goes to the switch and the other to the chime.
Old 08-15-20, 11:26 AM
A
Thanks for identifiying it as a doorbell thing.
the other wires hunt continues!
But we did find a switch in the hall closet! dunno what it is for. not the outside light
Old 08-16-20, 09:04 AM
Sometimes, on new construction, lazy drywall hangers will simply wall the security wires up. If you attic is navigable, you might be able to follow the security wires to where they converge, so you know where to look below (assuming attic routing).
Old 08-19-20, 05:14 AM
G
Received 6 Votes on 6 Posts
Go on eBay and search for "wire locator". The cheapies work pretty well. Will find wires behind drywall.
Old 08-19-20, 03:23 PM
Search for "wire tone for kit". They are also the best way to identify the individual wires once you find the home run.
