Moose Z1100 Battery failure
Received 0 Votes
I have a Moose Z1100. my low battery light is blinking. I changed the battery and when it does a self check the low battery light blinks. I checked the transformer terminals on the panel and I get 16v. I checked the red and black wire coming off the panel and i get no reading. I checked the 4 fuses with my meter and all are good. any help would be appreciated. Thank You
Try powering down and back on.
Especially on a system this old, the charger can shut down if the battery fails deeply, and a reboot will (usually) resolve it.
Either F3 or F4 opening will make it do this. There is a little hidden "foil fuse" that _could- be the problem, but it's not easy to find or replace.
Try the command 7 which forces a battery test,
Given the age, a charger failure isn't impossible.
https://static.interlogix.com/librar...anual_1996.pdf
