NX-1300E instant question
Old 11-28-20, 12:25 PM
C
Hello, I'm using a new NX-1300E LED Keypad and when I enter my code and hit stay twice it does not light the instant light. Everything else appears to work. Please advise. Thank you.
Old 11-28-20, 12:55 PM
Received 116 Votes on 107 Posts
We've moved you to another thread because you are asking questions about a totally different brand and model system than the thread you tagged onto:
That said:
That instant toggle feature isn't enabled by default. It has to be turned on in system programming. Do you have the installer code and a copy of the installer manual (Is your system an NX 4, 6, 8, or the V2 version of one of those?).
Old 11-28-20, 01:20 PM
C
Thanks for your reply. I do have the manual, it shows NetworX Series.
Old 11-28-20, 01:42 PM
The three models share a common configuration model, so this feature is common to all of them; but there are other features that are not common over the the different models. Knowing which specific version you have may prevent you from trying to use a feature that may not be available.
It sounds like you have a USER manual, which is totally different from the installation/configuration manual. The user code is also different from the installer code.
Old 11-28-20, 02:19 PM
C
Correct. I only have the user's manual. The brain box in the closet indicates NX-6V2 if that's helpful.
Old 11-28-20, 05:23 PM
NX-6V2 installer manual: https://static.interlogix.com/librar...n%20Manual.pdf
To turn on the feature you are wanting to use:
*8 [installer code]
0# (go to main control programming)
23# (partition 1 feature selection)
press * (to move to segment 2)
press 8 to turn ON the instant toggle feature
press * to save the change
press* three more times to return to programming location selection
press the [EXIT] key twice to exit programming
Old 11-29-20, 01:28 PM
C
That worked perfectly and the instant feature is now functioning properly. Thank you so much for your help and expertise! Very much appreciated!
