DSC WTK5504 shows panel unresponsive
DSC WTK5504 shows panel unresponsive. The LCD keypad works fine after hook up. whem selecting "MORE" then "INSTALLER OPTIONS" the display shows "Panel is unresponsive"
Hi and thanks for the response. I think I figured that out. it connects to a TR5164 wireless transceiver which is wired to a pc1864, ver 4.6. I don't think my transceiver was getting power. The problem I have now is that no matter how I organize my zone wiring the keypad(WT5504) shows an open zone. would you know if a PC1864 could have a board fault to fault out that way
Thanks again
Thanks again
Thanks again
Thanks again
Hi and thanks again. I stopped using the 5501. I have 6 zones. 3 contact , 3 motion. With every doors shut I used a multimeter at the pc1864 to verify the 3 contacts sensors were closed across their wires. I also used the resistors across the 3 motion locations to close them on the pc1864. Even after all that my zones showed open when i started the the WT5504
Thank you for all your help. I have decided to throw in the towel on the system and are returning the whole thing. we will find something else that is more user friendly. All the best!
