1 keypad button does not work
Old 12-03-20, 06:43 AM
I
I have a DSC PC5010.
One of the buttons on the keypad is not working. I want to change the code. How do I change the alarm panel code?
Old 12-03-20, 06:58 AM
Which button isn't working? You may or may not need it to change the code.
Old 12-03-20, 08:05 AM
I
Thank you.
It's one of the buttons used to activate/deactivate the alarm. I'd like to be able to change the code.
Old 12-03-20, 03:51 PM
Received 116 Votes on 107 Posts
Programming the Master Code
To program the Master Code, enter [✱][5][current Master Code][40][new Master Code]. The Master Code must be four digits unless otherwise indicated by your installer. Enter digits 0 through 9 only. Press [#] to return to the Ready state.
User manual, Page 7: https://cms.dsc.com/download.php?t=1&id=12831
Old 12-04-20, 09:12 AM
I
Thank you. That worked. I was able to get the code changed.
Old 12-04-20, 04:11 PM
If one (or more) of the keypad buttons is becoming non-responsive, a quick fix that may fix it is to power the system down (no you won't lose any programming, you will just need to set the time and date), then open the keypad and clean the dark patches on the backs of the keys, and the contact points on the circuit board with a cotton swab _lightly_ moistened with denatured alcohol.
Over time, skin oils and general grime build up on those contact points, and a cleaning may buy you some time before you _have_ to replace the keypad.
Old 12-05-20, 08:42 AM
2
Received 72 Votes on 62 Posts
Can a DSC PC-1500 keypad be opened to clean contacts? How?
Old 12-05-20, 10:29 AM
On many of them, if you remove the face from the base plate, the membrane with the keys comes off with the face, exposing the backs of the keys, and the contact points on the circuit board. Not all do, and it's been long enough for a PC1500, that I don't rightly remember.
2john02458 voted this post useful.
Old 12-18-20, 08:40 AM
K
Received 1 Vote on 1 Post
Sorry for bumping a slightly old thread but I confirm that its possible to clean PC1500rk membrane contacts for keypad. After removing keypad from wall, you have little plastic clip on the bottom which holds circuit board in place. Just carefully bend it while pulling circuit board out from the faceplate. Clean both circuit board and membrane with alcohol. You can even replace membrane with newer generation PC1555 keypads, or even replace whole faceplate if its really worn out, just led descriptions wont match but it will fit just fine. Done that myself, but opposite way (took membrane from pc1500rk and installed it onto pc1555 keypad with worn membrane).
Old 01-02-21, 03:03 PM
2
I actually used Isopropyl (rubbing) alcohol. Worked like a charm! Cleaned both keypads and now they both work perfectly. The hardest part was getting the keypads off the backplates.
Thanks guys.
