Vista 20P WILL NOT ARM
I have a Vista 20P with a 6160V keypad and the Alula Bat connect. A few hours after I installed the Alula and everything tested perfect with my alarm monitoring service, I later tried to arm for the evening and nothing happened?
The keybuttons beep as usual but the system does nothing when I enter my four digit code and press away or stay. It is almost like the system is ignoring my four digit code
Has that code worked before for arming ?
I believe you cannot use the programming or master code for arming purposes.
