CADDX CSD-40 Siren driver - docs?
Old 12-22-21, 12:33 PM
U
Received 3 Upvotes on 3 Posts
I just obtained one of these in a second hand system, and was looking for the installation/ spec sheet on it, to explain the terminals, power, etc. Have not been successful with Google.
Thanks,
Dave.
Old 12-22-21, 12:53 PM
Received 4,047 Upvotes on 3,631 Posts
Welcome to the forums.
It's a five terminal dual sound 30 watt siren driver board.
It requires approx 2A @ 12vdc
The output into 8 ohms is around 25-30 watts
There should be two terminals for the speaker.
One terminal for yelp tone
One terminal for continuous tone
One terminal for input ground.
Old 12-23-21, 07:28 AM
U
Right. So which are inputs and outputs?
So far I'm assuming the speaker terminals connect to the siren. And from my DSC PC1832, the "Bell" terminals connect to the GND, and Yelp?
Old 12-23-21, 08:59 AM
Yes.... that is correct.
Don't use a speaker of less than 8 ohms.
Don't connect two speakers to the board. If you do.... they must be in series.
This high power alarm module will tax your panel.
It is imperative that the battery be in good condition.
