Old ADT phone line zone bypass question
Old 02-13-22, 12:25 PM
P
After installing a new wireless system, I kept my old ADT wired system (model FA145C) in place since everything still worked. I no longer have a home phone line so I'm getting the Phone "not ready" on the display. I can manually bypass that zone, but how can I permanently bypass the phone module so I don't have to manually bypass? Thanks!
Old 02-13-22, 06:00 PM
Received 17 Upvotes on 17 Posts
When you say a new wireless system, do you mean adding some wireless sensors and a wireless receiver to your old system, or a complete second wireless security system?
Old 02-14-22, 06:03 AM
P
I added a completely new system, totally independent of the old system. Thanks for the clarification.
Old 02-14-22, 03:07 PM
Received 314 Upvotes on 289 Posts
Is this showing up as a communication error, or is it coming up as an actual alarm zone?
If the latter, they probably put a wired tamper switch on the phone jack, and the quickest, easiest way to resolve that is to replace those wires coming from that tamper with a 2000 ohm resistor at the panel terminals that they are connected to.
The FA 145C is a slightly modified version of the older standard Ademco Vista 20se
Installer manual: https://www.reedsecurity.com/pdf/Vis...UserManual.pdf
