My house has many hardwired smoke detectors that are interconnected. I only have one hardwired heat alarm in the center foyer ceiling that I am lookin the replace.
The existing heat detector:
ESL model 429CT (photo below)
Wire bar has two - and two +
Junction box has a red and green wire just tucked away
Junction box black wire connected to one of the two positive posts
Junction box yellow wire connected to one of two negative posts
There is no white wire in the junction box (just black, yellow, red and green)
All wires are a very small gauge
Replacement heat alarm (photo belowp:
First Alert model HB6135FB
Came with a three wire lead (terminal end); black, red and white
Do I connect the yellow junction wire with the white lead on the new alarm cable? Since I only have one heat alarm I will assume it is not interconnected with any other alarm in the house, so the red wires remain unconnected. I'm at a lost understanding the yellow lead to negative post on the old alarm and the white neutral lead on the new alarm.
It is likely that the "yellow" wire is just a white wire that has been discolored. You can confirm this by using a meter and check for voltage between the black and the "yellow" wire. You should get 120 volts between the two wires.
Interesting! I totally skipped the 6/12v fire panel reference in the installation guide. Guess I will have to purchase the same exact unit (or a replacement model) as the one I purchased is incompatible. Much appreaciated.
I didn't read your original post close enough. You have an alarm panel with multiple detectors on it and you want to replace the one in the picture. That is a photo smoke and heat detector. These are two wire low voltage smoke detectors that are designed to work with a particular system. I couldn't read the date code on yours but smoke detectors are required to be replaced every ten years.
These two motion sensors are in my house. The wiring is different. Any idea why? I assume these resistors are only for tamper. Maybe one is wired correctly and the other not. I am getting an error on the panel (Vista 20p) with the zone for the second picture.
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x948/20221110_192930_eed6ad5ee1c2e4e3ac84b43c325cfe7cc63f2d68.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x948/20221110_201338_cb283b3b4a89c5d1379d742993aae1d4e6b7ef8c.jpg[/img]
Hi,
As stated, I have an Ademco via30+. I Inadvertently changed the settings and it wiped all my sensors. I set up my sensors back, but now I need to change the installer code. When I reset the power and [*] & [#], I do [*] [2][0] [#]. I assume this asks me to enter my new installer code, but when I enter 4 digits, it does nothing. For some reason, I have to enter a [1] before I can enter a new code. Otherwise, it goes to [2] house ID or [4] primary number or some other settings according to their number. When I enter my 4 digits after the [1], I get beeps confirming it changed. If I enter 1234 as the code, and ask it to repeat using [#][2][0], it repeats [11][02][03][04]. Is my installer code 1234? I exit using [*] [9][9], but I can't enter Programming mode with [1][2][3][4] - [8] - [0] like I used to with my old installer code. Is anyone able to help?
This is my keypad
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1724/20220306_234146_409912fd7ca4cbdb921975c0ddaaa9fe75f64bf8.jpg[/img]
Thanks,
