How can I test a cat 6 cable
Old 05-25-23, 07:54 PM
B
What kind of equipment can I use to JUST test a cat 6 cable? I do not want anything fancy. I had to run a new cable because I was told the cable had to be bad. Then I found out the camera did not work all the time.
Old 05-25-23, 08:03 PM
Received 3,485 Upvotes on 3,128 Posts
If you're a hobbyist you can get two RJ45 jacks and use an ohmmeter.
Otherwise there are dozens of inexpensive cable testers.
Cat cable checker
Old 05-26-23, 04:13 PM
B
Thanks
