Ademco Lynxr- one sensor governing two windows
Old 04-13-24, 10:54 AM
V
Received 1 Upvote on 1 Post
Bought a house that has several double and triple windows, where the original installer put a sensor between sashes to govern 2 sashes with one sensor. This happens in about 3 different sets of windows throughout the house. However, at one set, there's a problem: with the chime on, to indicate the sensor going off when window opens, one side of window chimes when opening, but the other side doesn't. How could the sensor work the left side sash...but not the right side sash?
Old 04-13-24, 11:13 AM
Received 4,049 Upvotes on 3,632 Posts
Did you check it by opening and closing one window at a time ?
If yes.... it may be a bad switch or one switch isn't wired.
You'd have to carefully open the transmitter to check the wiring.
Old 04-13-24, 11:26 AM
V
yes, checked one widow at a time, but one side is not being recognized. Also changed the battery for the heck of it. I'll carefully inspect wiring, but I think that is going to be right. If wiring OK, you'd be suspicious of sensor?
Old 04-13-24, 11:31 AM
Yes. Those switches do go bad.
You should find one wire from each switch connected together and capped off.
Then one wire from each switch on the screw terminals.
The two switches form a series closed loop.
It wouldn't hurt to replace them both.........an example.
vett82ce voted this post useful.
Old 04-13-24, 11:42 AM
V
Think you're right. Will just change both and see where it stands...
