Ademco Lynxr announces which door is open...
Old 04-13-24, 12:57 PM
V
Received 1 Upvote on 1 Post
My Ademco Lynxr announces which door is open, in addition to the usual chime beep. I don't care for that. A simple chime beep is all I want when having chime "on". I looked through manual but didnt see exactly how to remove the voice designating what window or door is open. Can someone direct me to that? To reiterate: I want just the beep when in chime mode, not the voice.
Old 04-13-24, 01:23 PM
Received 4,046 Upvotes on 3,630 Posts
It looks like all or nothing..........
CHIME KEY: Turns the Chime mode on and off.
When on, any entry through a protected delay or perimeter zone while the system is disarmed
will cause a tone and voice descriptor to sound at the keypad.
vett82ce voted this post useful.
Old 04-13-24, 04:00 PM
V
Sheesh!
Old 04-15-24, 06:24 AM
P
Received 11 Upvotes on 11 Posts
Been a while since i worked with one of these, but i *think* you can just clear out the voice descriptor in zone programming. I don't have a manual in front of me but should be fairly easy.
Old 04-15-24, 08:31 AM
V
yeah, that's what i thought when i read the manual. I tried it today just to see if it worked, but I must have done something wrong...didnt work for me.
Old 04-15-24, 10:41 AM
P
I pulled up the manual just now and looks like you would enter the number 99 for the voice description, which erases whatever was previously programmed.
Old 04-15-24, 05:14 PM
V
yeah, i tried that "99" when i tried it but nothing happened, but like I said, I think I did something else wrong. I will try again...
pearljammer voted this post useful.
Old 04-16-24, 06:38 AM
Received 312 Upvotes on 287 Posts
You have to do it in *84 programming, for each zone. Problem is, I think it will still announce the zone by zone number.
Do you have the installer manual: https://www.avss.net/PDF%20Files/Ademco%20Lynx%20RI.pdf
Old 04-16-24, 12:56 PM
V
Yeah, i have that manual. When I have time I'm going to go through it more carefully.
