exterior caulk
Old 03-24-03, 03:17 PM
aaronr
exterior caulk
I've noticed that the exterior caulk around our windows is starting to pull away and gap. Do I need to remove it completely before recaulking? Any tips for recaulking the exterior such as what type of caulk to use, etc?
Thanks
Old 03-24-03, 10:10 PM
bungalow jeff
You should scrape and pull off as much as possible. After all other repairs, sanding, patching, etc. ana a good primer, recaulk the gaps. Anything wider than 1/4", if you have determined it is not a new problem, use backer rod (foam tubes) to stuff in the gap and caulk at the surface.
Old 03-25-03, 06:48 AM
aaronr
primer?
What do I need to prime? Does exterior caulk require some pre-treatment of the surfaces? Our house isn't that old, and most of the trim work is that Hardie-plank stuff. It's in good shape, and the windows are in good shape. I think it's just the caulk that sucks.
Old 03-25-03, 10:54 AM
bungalow jeff
If it is just the caulk, then clean the surfaces of any dirt or loose paint and reapply caulk.
