vapor barrier
Old 04-22-03, 07:30 PM
ajc
vapor barrier
I am currently building a house in Southwest Virginia. The contractor is currently working on insulation and wall board (we will have plastered walls & ceilings). The insulation contractor plans to use blown insulation in the attic spaces. I inquired about a vapor barrier for the ceilings. He said that the wall board has a paper cover and that will serve as the vapor barrier so no additional vapor barrier was required. Is this correct?
Old 04-22-03, 09:47 PM
http://www.eere.energy.gov/consumeri...riefs/bd4.html This is a Dept. of Energy brief on Vapor Diffuser Retarders (VDR) or vapor barriers if you prefer.
The manufacturers of cellulose state their product does not require a vapor barrier because of the characteristics of their product. This is widely done.
Wall board that state it has a vapor barrier will have an aluminum foil on one side and not paper. Paint can also act as a vapor barrier.
If you read the brief, you will see that it is more concerned with the air barrier than the vapor barrier and cellulose is a superior air barrier than fiberglass insulation.
So to answer your question, what the contractor said about the paper on the wall board as being a vapor barrier is probably not true. And you don't require a vapor barrier with cellulose insulation.
