installing vinyl Cedar Impressions siding
Old 06-28-03, 08:37 AM
molleb
Question installing vinyl Cedar Impressions siding
I would like some help with installation of CertainTeed Cedar Impressions vinyl siding. We have started the project and have reached the top of the house. There is a 6" gap. We will cut the siding but the J-channel doesn't hod it snug. We tried slotting the siding and nailing it down, but the nails show. We were told that there was a type of flexible channelling that you could buy to slip behind the siding to hold it taut. Does anyone know what I am talking about? Or does anyone have any ideas? Thanks.
Old 06-29-03, 08:32 AM
R
http://www.certainteed.com/ I suggest that you go to this site and ask your question. I am certain that they will have a solution for you with instructions on how to resolve this problem. Furthermore they will probably have the product you are looking for.
Old 07-04-03, 04:58 PM
bbb
3m tape or glue should support. 3m tape is very strong and lasts forever.
Old 07-11-03, 08:27 AM
jmiddleton
You need a product called undersill finish trim. It is used to hold the cut edge of the siding under window sills and the last strip at the top. There is an art to cutting the siding for this last row - it needs some "tooth" so the finish trim will hold it in place. There is no mechanical fastening for the last row - just the friction between the siding and finish trim.
