um....how do I get my caulk gun working?
Old 10-30-05, 05:37 PM
MicahWedemeyer
Hi,
I know this is really dumb, but I cannot figure out the caulk gun for the life of me. I cut the tip of the caulk tube, loaded it in the gun, and pulled the trigger a bit. Instead of coming out the tip, it oozes out the back into the gun.
I read the directions on the caulk, and they mentioned something about piercing the inner seal. I tried jamming a nail down the center of the tip, but it went in and came out without touching anything.
What am I doing wrong?
Thanks,
Micah
Old 10-30-05, 05:43 PM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
Use a longer instrument, Micah. The inner seal is even with the base of the nozzle. A screwdriver will usually do the trick.
Old 10-31-05, 05:58 AM
B
The caulk gun should have an attached piece that is meant to puncture the seal. If you can get a screwdriver in there, chances are you are cutting the hole too large (unless your are covering large gaps). If your caulk gun doesn't have the seal puncturer attached a piece of wire works well.
