Closing gap in drywall to crawlspace
Old 01-20-07, 09:51 AM
Hi,
We have a crawlspace under part of our basement, which extends to the garage at one end.
I recently discovered that the drywall in the garage on the wall facing the crawlspace has about a 1/4" gap at the bottom - leaving full length "gap" that allows cold air to draft right into the crawlspace.
So I want to insulate this spot, but I wanted to first "close off" this gap - I doubt that spackling it all the way across is a good idea, is it? Easiest would be putting some molding on the garage side all the way across, to close the gap, then maybe use foam insulation on the inside? Is there a better way to do this?
Hopefully I explained the situation adequately.
Thanks,
-Jim
Old 01-20-07, 03:52 PM
T
Same issue on my current home that I just bought.. I'm finding air leaks all over the place (85 yr old stone house). I'm using can after can of foam sealant with great results... and using trim work to hide the gaps....
Old 01-20-07, 04:06 PM
T
A 1/4" gap can be caulked.
Old 01-20-07, 10:11 PM
Who's Avatar
Who
Who is offline
Received 1 Vote on 1 Post
If you have a small water spill, you really don't want the bottom of a drywall sheet wicking up all the moisture. Cover it with baseboard if you don't like it's look. It isn't insulating so I wouldn't caulk the bottom - it would be a waste IMHO.
Old 01-21-07, 09:18 AM
Thanks for the ideas - I'll probably use some trim to close the gap on the outside, then insulate from the inside somehow - maybe the foam cans or caulked styrofoam insulation.
-Jim
