Sealing HVAC Ducts in Basement
Old 12-08-07, 05:24 AM
B
I've noticed that the ducts from my HVAC units in the basement definitely have small leaks and even some visible gaps in them as they run through the basement to/from the rest of the house.
I saw some different kinds of duct tape at Home Depot. Also some of that foaming spray.
What's the best method to both detect and seal off these areas? I can't imagine how inefficient my two HVAC units must be, and the extra costs as a result.
Old 12-08-07, 07:06 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
If this is a conditioned basement it will save you no money to seal the holes. If it is not conditioned duct seal is the best way.
Old 12-08-07, 07:12 AM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
airman, is the "duct seal" you speak of the semi-liquid/pasty compound that is painted on with a brush?
(not sure the OP knows what you mean and this gets you to explain)
Also, where would one get that stuff. I do not remember the typical home supply stores with it.
If that is the stuff airman speaks of, it is the only way to roll. does a fantastic job.
Old 12-08-07, 07:42 AM
B
Airman - thanks. the basement is not conditioned. unfinished.
Nap - yep, your right. I thought Airman mean the duct tape stuff in HD.
So this stuff is liquid, huh? It's specifically called "Duct Seal"?
EDIT: Is this it?
https://www.homenetworksupply.com/pr...ac=4&zmap=DX-1
Old 12-08-07, 11:07 AM
nap's Avatar
nap
nap is offline
New Member
No, that is a putty for filling holes and such. You want a mastic sealant. Something like is shown in this image
ca't tell you what brand is best. I'm a sparky, not a tin knocker. although that pic does not show the stuff I see the commercial guys use that seems to work very well.
the stuff I see used is kind of a dark gray/green ooey gooey stuff that can be applied with a brush. It does an excellent job.
Old 12-09-07, 06:19 AM
Yes Ductseal like in the picture! Can buy at any HVAC company/store.
Old 12-10-07, 07:24 PM
Tolyn Ironhand's Avatar
Received 352 Votes on 304 Posts
In commercial jobs I see the tinner's use the stuff you put on with a brush. Has a bit of stretch and gets into cracks. Or the metal tape. That stuff is really sticky and strong!
